Does anyone know if the 5.7 engine block holds 5 quarts of oil, or is it more? I have a 2000 315 HP. I have an old version of that engine in an automobile engine, and it holds 5 quarts. I only ask because some of the newer v8's hold 7 quarts.
oil capacity
Mine holds about 5 even; I would add 4 and add a half quart until I had it full. I read my dipstick on the water, or in the drive with the boat level.
Auto 350cid were usually 5 or 5.5 depending on pan size. I had a tahoe with 5.5, and a c/k with 5.
I started running Schaeffer's Moly Blend 40W this season. I'll see how it does.http://www.wakeboatworld.com
[]) [] []V[] [])
07 22 Ve with MP 340, service tech from my dealer told me that mine only held 4.5. This arose from questions I had about consumption. Come to find out I was overfiling and thinking the engine was using more that I thought, based upon what I was draining out. I switched to synthetic on last change and not sure if that has helped. Best to add & check as you go to find out exactly the amount it holds.I don't want to go to work, take me wake surfing instead!
The next issue is figuring out the filter number. The filter on it is a fram, and it is a PH30. The AC Delco equivalent to that is a PF454. There is another AC Delco, the PH1218 or 1214, I can't remember which, that would fit as well. That second AC Delco filter is the filter on most 5.7 GM's of the late 90's and early 21st century. It appears that the filter that is on it was the filter for camaro's in the early to mid 90's. I'll probably just call Tige tommorrow to confirm.
Check it before you drain, put back the same amount you drain, plus what is needed to bring it up to the safe mark.
In other words, if it's low, and you drain 4qts, add 4qts plus enough to bring it back to full. If it shows full, and you only get 4qts out, fill with 4qts.
Dont forget the 1/2qt in the filter.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
There is a short and long filter that fits the 5.7L. If you've got the clearance, go with the long.Originally posted by illiniboarder88 View PostSpharis, the thing that I found weird is that two filters fit it, but holds more oil than the other.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
illiniboarder88, (NAPA : 1069)Originally posted by illiniboarder88 View PostThe next issue is figuring out the filter number. The filter on it is a fram, and it is a PH30. The AC Delco equivalent to that is a PF454. There is another AC Delco, the PH1218 or 1214, I can't remember which, that would fit as well. That second AC Delco filter is the filter on most 5.7 GM's of the late 90's and early 21st century. It appears that the filter that is on it was the filter for camaro's in the early to mid 90's. I'll probably just call Tige tommorrow to confirm.
If you have excel, I can send you a file that has Napa part numbers for oil filter, oil/water seperator, belt number, oil used, impeller and impeller hsg numbers and my winterizering instructions. You can PM me w/ and email address and I will send what I have.Dale
2000 21i Tige
