I went and looked at an RZ4 this weekend, and was wonder if you guys could help answer some questons for me.
How bad will black look on a boat if it never gets wiped off after use(the only black is the side panel, hull and middle section are yellow). I put my boat in a hoist after every use and it makes it almost impossible to wipe down.
How much raddeling happens in the Z tower, the tower on my 22v is horrible.
Does any have problems with the board racks on the Z tower. I don't like how they don't lock in place when folded in and the screw for them is a little poorly designed.
Has anyone had problems with the kicker amps heating up to much and not being able to handle four wet sounds on the tower?
