After 5 years the rubber starts to get brittle. On radials, the tread separates from the tire because the tire pattern actually puts sideways pressure on the tire so that it tracks better. If you're in hot weather, 5 years and they will start to go quickly. I'd check them for signs of cracking if you plan to wait. I ended up getting bias ply because I had to buy 2 in short order from Walmart. The only other place that sells them is Magnum, and they're so backed up you're lucky if you can get them to mount your tire in 4 weeks. What a PITA! I finally ended up buying tires there and getting them mounted elsewhere. You'd think one of the tire places would carry trailer tires
