waws just thinking it might be cool to have tower light but didnt know how hard it would be to do my self
Tower light
Go to you Lowes or Home Depot and get a fish tape. I will not take you any time at all to pull the new wires.Originally posted by byfor5 View Postya but it seems like from dash to tower would be easy just up through the tower would be hard
http://www.homedepot.com/webapp/wcs/...2&ddkey=Search
I did it on my last boat.Ran wires for tower lights and speakers.Not hard just requires patience.I actually used a mason string(like kite string) instead of a fish tape.I tied a small nut on the end and dropped it from top to bottom.The exit hole was on the bottom side of the tower tubing and after a few shakes of the boat the nut and string fell out.A coat hanger used as a hook really helps.I also ran the wire threw the tower base and into the boat so I wouldnt have any holes. Good luck---v^---v^---v^_____---v^---v^ For a second there. I was bored to death!!
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
The way I hear it most explained on Wakeworld is to put a piece of tape on the end of a long strand of dental floss. Use a shop vac to suck it through and then just pull it up with the dental floss. I have heard many folks say that did the trick for them when everything else failed.Be excellent to one another.
I think Tequila also said a cotton ball tied to dental floss would work also.Originally posted by talltigeguy View PostThe way I hear it most explained on Wakeworld is to put a piece of tape on the end of a long strand of dental floss. Use a shop vac to suck it through and then just pull it up with the dental floss. I have heard many folks say that did the trick for them when everything else failed.
