Air Duct replacement
    I have a 2008 RZ2 where the air ducts are ripped. Should these be replaced? If so what is best to use?
    Yes, they should be replaced. The are what helps vent the bilge of heavy gas fumes both while the boat is stationary (with blower going) and underway (front intakes and ducts).
    Standard corrugated bilge vent hose is just fine. Should last a number of years as long as its not disturbed. If you find the front vent tubes get a lot of abuse, then there are similar corrugated tubes that are more robust then the standard vent tube. Just cost more.
      This what I used. Takes a beating and cheap. Screw one end on to the top and flex the bottom in. I think I didn't even have to cut it.
