Distributor and ignition coil questions for a 2000 Tige 21V Mag
    I have a 2000 Tige 21V with a Mercrusier Mag engine. I am looking to replace the ignition coil, distributor cap, and rotor. Does anyone know which cap, rotor, and coil are compatible with my engine? When I google/Amazon search for the part it comes up with thunderbolt I and IV. Is that what I need to purchase?
    Thanks for the link!
      Originally posted by TeamAllen
      You should be able to enter your engine serial # and get the part #s you're looking for in the diagrams.
      https://www.perfprotech.com/mercury-.../04/mercruiser
      Where can I find a PCM site like this? Not finding anywhere to get part numbers.
        https://www.nautiqueparts.com/
        You can't search by serial # but most parts will list which application PCM they are for. Use the search bar in the engine parts section
