Liquid Lumens Top-Side Lights
    Has anyone installed LL Top-side Lights on the transom of your R-Series boat?
    I have a Tige R21 and can't find a flat surface that is either 2x3' or 6' long. I think I have to go custom length and hoping for inspiration.
    Thanks.
    I’m a LL dealer and there super easy to install get ahold of them direst and they will send you a custom length that you want. Also you can go through myself if needed. But usually they are built to spec.
    surf till u die.
      After talking with them about the same issue I found out that you can cut them to the length you want similar to a regular led strip. You will loose the warranty if you do though. My length was going to be a few inches short of 6'. They said cut it, silicone the end just like it was and then put the end cap on. At this time I've decided not to get them as we are almost never on the water after dark.
