Help with Diagnostic codes
    Can anyone help with this engine code dealer told me to bring it in but that a 4 hour drive one way. He said he couldn’t tell me what the code means without seeing the boat.
    Heater in the o2 sensor. Would have to check at my cheat sheet at the shop tomorrow to tell you which bank
      Paden, you’re obviously wrong. As the OP mentioned the dealer tech needs to have the boat in order to check codes. Not sure why you think you can just look it up on some cheat sheet. Those dealer techs!
        Kinda like a $130 diagnostic fee to look and see that the bent prop is causing the vibration?
          Hahah. Well, let's just say I've seen enough 3000# codes to know that's an o2 sensor.
          Silver Fox, PM me your email or cell and can try and help you out tomorrow.
          All the codes in the 3000s are o2s(you can get some STFT codes that are o2 related as well). Little more leg work and you know which bank and if its pre cat or post cat. I'm a huge nerd though. I get back from service schools and print off the thumb drives manufacturers give just so I can have a hardcopy. Lol.
          Oh ya, bent prop diagnosis is a standard one hour charge Mike
            Bank 1, post Cat.
              Boom. Majestic for the win.
                Unbelievable!!! Thank you guys so much. Any advice on on changing this out?
                  Is this the part I need?
                  https://www.bakesonline.com/indmar-e...manifolds.html
                    If you see this code on your cheat sheet, lemme know.. dealer has it now, so it’s no biggie if you don’t, but I’m curious what almost screwed our day up.. I thought it was O2, but maybe it was something else.
                      Its a fuel pressure voltage low code. I believe that's voltage on the fuel rail. I'm not Idmar tech so i'm just guessing lol! Not sure if Indmars have a FCP sensor or not. (Fuel compensation pressure)
                      Oh Yeah!
                        Yes, that is the one. You will need an O2 socket as well. Can be purchased for around $17 or so at any auto parts store(you can actually get to the post cat with just a wrench as well. Bank one is going to be the port side exhaust
                          I’m guessing the loose O2 sensor, and it subsequently going away, was just pure happenstance then... hmmmmm..
