E series Tower gasket
    I noticed the other day that one of the legs of the tower was loose and the bolt had come completely out. I re inserted the bolt, however the rubber gasket that goes between the leg and the fiberglass is gone. Anyone know where or if I can get a replacement for this?
    Just started searching this also. My Winter project.
      e-series tower - how to replace the pads between tower and boat?
      Put this in search. Good info.
        You would likely have to get a dealer to order you one straight from the factory for you
