Ballast Questions
    Ballast Questions
    2017 RZX3
    I added WakeMAKERS PNP bags. Just now paying attention to fill times and made some observations and want to make sure this is common
    Front bags fill up very fast and overflow and are very close to the same time within a few seconds of each other.
    Rear Bags are very slow and PNP bags only fill once the rear stock bags are full.
    Is this correct? Appreciate the help as usual.
    In a sense, yes, the sub-floor sac has to fill first, since the PnP sac gravity drains into the sub-floor sac.
    Flow rate didnt change, but rather you upped the water capacity by about 67 gallons in each side.
