We keep a pair of what I call "battle tubes" on hand. We run two long lines off the stern, hook one tube to each, and drive the boat to have them hop the wakes and bash into each other while the riders try to kick each other off their tubes. They're like a set of human "clacker balls" from the 70's. I know this is perhaps not always the intended use for these things but it's probably the most entertaining boating activity we do - for the passengers in the boat, that is! {grin}
On our present pair the interior walls have separated from the outer walls, such that they're becoming more spherical than disk shaped. Makes for some really wild rides - it's a disadvantage in terms of stability, but like a fighter jet that instability can be used by a clever rider to steer and control impacts. It's time to replace them again.
We've learned there are subtle differences in these tubes. Where the tow point is located, for example, has a huge impact on how it rides over the water and whether it is likely to dive after landing a wake jump.
Any recommendations for tubes to favor or avoid? The market seems to change every year so I don't know what's "good" and "bad". I don't mind buying last year's model if its known to be a good choice, and I bet eBay is full of overstocks. We prefer those that have an inner inflatable tube and a heavier outer protective sleeve, such that the top and bottom surfaces are flat rather than with a hole like a doughnut.
Thanks!
Thanks!
