I am buying a 2018 rzx3 from Germaine in Provo I wanted to know how to weight it I have a 1000 pounds of lead. It does not have PNP in it. I am picking it up on June 1 and headed to Lake Powell for vacation. Any help would be greatly appreciated
2018 rzx3
It does not have PNP in it.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
If at all possible, I would never buy a new boat and then head to a remote, expensive vacation without running it a time or two on my home lake. These boats are hand built, and often have problems. I believe the dealer is supposed to take it out and have a checklist to go over, but based on my readings on these forums, the dealer often does not do it, or things pop up a little later than that.
I am sure that Germaine will take care of you in the end, but if you can't take it out, make sure they do a good lake test for you. I am sure Elevated or another will chime in if I am off base on the dealer checklist.
1000 pounds of lead is quite a bit extra to be trailering with, a flat tire (or worse) near Hanksville in June is not any fun at all. Pretty much every tire I have seen on every boat is very close to stated capacity without the lead. When I've run lead, I usually take it out when driving 150 miles in the 110 degree heat. There is no shortage of people ballast whenever I've gone to Lake Powell.
Good times are in store for the Tonka family!Be excellent to one another.
