Hey T.O.!
I recently swapped my FAE supports on my 07’ 22VE from the swim deck mount with “quick” disconnect to the trim tab mounts so I figured I’d post a couple pics of the before and after.
No more messing with the disconnects every time I take my deck off! (It was a pain in the a$$ to do alone and I have to take the deck off every time I put it in my garage)
For those that have a swim deck attached support mount, I’d highly recommend the swap. Takes a little time measuring, cutting the pipe to size, grinding the ends so it fits the old style pipe mounts perfect, drilling bolt holes and you’ll most likely be using the one trim tab screw that’s actually a thru hull mounted bolt (
) but it came out great and is solid.
I also cut off about an inch and a half from the pipe so it sits closer to the taps plate. Had to redrill the retention holes for the flappers but that was quick and easy and worth it to me to get a cleaner look from the side.
Old
New
) but it came out great and is solid. I also cut off about an inch and a half from the pipe so it sits closer to the taps plate. Had to redrill the retention holes for the flappers but that was quick and easy and worth it to me to get a cleaner look from the side.
Old
New
