Have a 2009 Tige RZ2, love it BUT the wake is just ok and on the goofy side is pretty poor. I bought one of the Surf Gates and that worked pretty good but the the velcro and swap over to other side a big pain. And 4 black velcro patches on the side of my boat very objectionable. Want to have a mechanical or hydraulic system installed. Anyone have info on kits or installers? Thanks
Wake Gate or alike
There's also suction cup options that work well. No Velcro involved.
https://nauticurl.com/collections/wa...aper-surf-gate
I would like to see this. How does the center tab make any difference on the surf wake?Originally posted by 18c racing View PostI offer custom taps plate that replaces your stock one that really helps out and there bout 20 min to install a lot of my customers use my plate with a nauticurl or mission and are really pleased with the results .
fred,
what is your ballast, TAPS and speed setup? In regards to ballast, what does the boat have built in or extra as a whole and whats the setup used that lead you to the side mounted surf devise?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I have a 2011 RZ2. I've had pretty good luck with goofy surf wave by listing boat. Decided this year to try a suction cup gate and felt I could get as good a wave as listing. I'm not an expert surfer by any means. I like not having to list and be able to keep my ballast fairly even since I surf goofy and others are regular so it was easier and faster to switch sides. Problem was having the suction cups hold every time. So yesterday I started email to Wakemakers about putting the wave surf assist on mine
Your surf gate probably isn't the problem. I have several hours in experimenting with the weight, speed, and TAPS on my RZ2 and it makes an excellent wake. I think most RZ2 owners agree it will make a better wake when slightly listed but not necessarily required. I shift most of my bow lead to the surfside so the gate is just barely under the water line. I run about 2400lbs of ballast with TAPS around 3.5. Personally I like my speed around 11.8 or 12, slower for less advanced riders. A fully automated surf system would be nice, but only if it made my boat exponentially better.If I'm not surfing, I'm making money to surf.
Well after a year of testing behind my old 2014 Rz2 and all other models of 2014 and older Tige Boats it works really well and I’d be happy to post up a ton of my customers feedback that love it.Originally posted by SONIC View PostI would like to see this. How does the center tab make any difference on the surf wake?surf till u die.
