Acme 2773 for 17 Z3
    Acme 2773 for 17 Z3
    Pulling the trigger on a prop today , ik alot use 2419 , acme recomends 2773 or 2775 , anybody run these ? If so quick thoughts
    If you wanna know what I did , come with me next time...
    The 2419 with its 12" pitch, will be the most aggressive out of the 3, but not by much. Only a 1" difference in pitch to the 2773 @ 13" and the 2775 falls right in the middle with 12.5". If you are boating at a significant elevation, then the 2419 would be the better choice out of those.
      Only at 850ft , so good on 2773 , gonna run 250 per side additional lead in the rear . Im good?
        Gear ratio is 1.5 to 1 ? Left rotation ?
          Isnt Tige using a 1.75:1 or something like now on the larger boats? left hand for sure and 1.125" bore.
            I have a Tige 2016 r22 it came with: Raptor 360, ZF 41 IV EL drive with a 1.46 ratio, 537 prop
              I ran the 2773 on my z and sent it back. If wasn't enough... just FYI.
              Germaine Marine
                Elevated did you have any prop burn with the 2419 also what was the top speed I have about a 25-minute drive by water to get to where we ride
                  None
                  Germaine Marine
                    1.5 with 1-1/8 on everything but the Rzx line. The Rzx line is now 2-1 with 1-1/4.
                    Germaine Marine
                      I run 2419 in Colorado with 4k ballast. It's a tractor.
