This is the first year that our boat will be in storage for the winter instead of the garage, so we have decided to add marine antifreeze to the winterization process. It is my understanding from reading other posts that 1) the engine should be completely drained, 2) the plugs put back in, and 3) then run the antifreeze into the engine using the fake-a-lake until the antifreeze starts coming back out of the exhaust. Is this correct?
Also, what is the best way to put antifreeze into the ballast pumps? Does it work to use the fake-a-lake to try to suck the antifreeze in thru the fill pump? or is there a better way to do it?
What about the heater? Should that have antifreeze as well? and if so, what is the best way to add it?
Is there anything else I am missing? Any other advice for leaving a boat in storage over the winter? Cover on vs. off? Anything to keep critters out?
Thanks in advance!
Thanks in advance!
