My vote is for the Blue & White. Maybe add the WS REV cans in Blue to match or as mentioned above the tower in blue and then keep the cans white. With all the new gel & decal options, I honestly think it is easier to just buy one on the dealer floor.
Need help deciding on color
This is electric blue with matching tower. Get a black or white tower. We had a terrible time getting the paint to match the tower for touch up. I ended getting the paint from boatmate because our trailer is also electric blue so that made me a couple of cans from the vin#. Both Tige and the dealer gave me a paint code for the dupont paint and suggested I go to car painter and have made. Where I work we have an autoshop which uses dupont and they said there is no univedsal code system for the paint it depends on the manufacturer. Different codes for different manufactures ie Honda, Toyota, tige etc.
I will never match the trailer again pia to do touch up. Easier if it was just black. Looks good but not worth it.
I like the blue and white.Last edited by whiteflash watersports; 11-24-2014, 03:37 PM.
My first boat was white with blue, and my second was white with black.
I really like both. You can't go wrong with the white hull. I may incur the wrath of my fellow Tige owners when I say this, but I didn't have to wash my boat ONCE this year. It still looks clean.
Only thing I wish I had was the white tower.
Surf X in the Z3 is just 900's per rear side. I can tell you from running demo's in Z3's without the VX that its not enough if you want a good wave with no crew. If you run a large crew they are probably enough, if you don't i would want more.Originally posted by Booms View PostQuestion -
Does the Surf X come with enough weight or will I need larger custom sacs?
I run about 1000lbs in the rear locker on my Z1 and it is great. My bubby runs the same in a Z3 and its a smaller wave. We both run with 2 or 3 people in the boat most of the time.ImageUploadedByTapatalk1416876499.478790.jpg
Boy, that's a crappy problem to have. I like the blue and white with the white tower. That pacific blue is SICKKK!!!! I wouldn't even care about what color the tow vehicle is, I mean the boat is on the water without it most of the time. Maybe I just don't have a nice enough boat and tow vehicle to bother me, haha
U sure bout that? Those new sacs look larger than 900 alone, then you add in the 250 tank. Im not question stated specs from Tige, but what you think they actually are?Originally posted by boardman74 View PostSurf X in the Z3 is just 900's per rear side. I can tell you from running demo's in Z3's without the VX that its not enough if you want a good wave with no crew. If you run a large crew they are probably enough, if you don't i would want more.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
@ Booms,
I would say that that advertised weight implies sac and hard tank, so total per corner. Based on Majestic's experience with the Z3 at the Polar Bear event, more ballast was not needed, although they did add some. This is only one early feedback with AVX, so its hard to tell right now. Seems the AVX hit late in the season, so not much on it yet.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
