I have never been around an operating Perfect Pass (or any other cruise control).
Regarding the mechanical portion of it:
As you move the mechanical throttle and get close to the set point and it beeps, I assume it activates the servo and then holds tension right there to keep the throttle setting where it needs to be for the set speed. This is correct?
From all the installation images I have seen, it looks like the PP cable "butts up" to the end of the actual throttle cable--so it essentially works in the opposite direction.....?
HERE IS WHAT I WONDER: when you adjust PP speed by clicking up and down, does it physically move the entire throttle mechanism? In other words, since it is all connected, does the throttle control lever move slightly as well when the servo adjusts the throttle?
So you can't move the throttle lever after Perfect Pass activates? By what I see, that would move everything and mess it up?
I told you the question was stupid. I know watching one work would be worth a thousand words, but I don't have one!
