I've used Babes, but for a daily spray/wipe down I like Hot Sauce the best. The babes vinyl cleaner is just as good as the Vinyl Sauce and the Babes vinyl conditioner is just as good as the Vinyl conditioner sauce, so they are equal as far as I'm concerned, but I have been using the Boat Bling products here just 'cause they are easier to get at local boat places.
The Hulu vinyl cleaner and conditioner works well at cleaning, but it leaves the vinyl a little on the greasy side compared to the vinyl sauce and conditioner.
The Hulu Polymer Sealant is a great exterior Gelcoat wax. I keep my boat in the garage, and wipe it down with hot sauce every time I pull it out of the water, but the Polymer Sealant has lasted my boat 2 years.
I just tried out the Performance Boat Candy Polish and Wax products, works great with a dual action polisher and the wax is a little easier to buff off compared to the Hulu product. I don't know if its going to last as long as the Hulu though, I'll know in a year how well it lasts.
Boat Bling hot sauce
3m Vinyl cleaner and prtotectant - I like better than the Bling vinyl products
yact brite serious shine is amazing and safe on all surfaces - electronics, vinyl, paint, gel, glass, etc etc but very expensive.
Performance Boat Candy Speed Gloss
Performance Boat Candy Crystal Gloss
Griott's Machine Polish #2 and #3 with random orbital
Performance Boat Candy Vinyl Cleaner
Performance Boat Candy Vinyl Conditioner
Hands down best thing about PBC is their Speed Gloss is amazing with water spots and still smells great. Beats Babes by a mile. I think it is somewhat better on water spots than Hulu or Hot Sauce.
PBC vinyl cleaner and conditioner beats Babes and is about the same as Boat Bling. I stay with PBC to cut down Shipping (They have many free shipping or super sales through the year).
Boat Bling for exterior wipe downs
Generic boat wash for full exterior/hull cleaning
Collinite #925 for waxing
Babe's Seat Soap for regular vinyl wipe downs
Totally Awesome - cut with water - for deep interior cleanings (use a medium bristle brush) and follow with conditioner
303 Aerospace Protectant for conditioning/UV protection
Have used Spray 9 and Magic Eraser pads on dirty vinyl a few times in the past. Takes the crud out of the tiny contour lines in the vinyl very nicely. Spray again lightly and wipe clean with virgin paper towel after crud is loosened.
Magic eraser works at removing stains because it's micro sandpaper that removes the outer layer of the vinyl. If you want your vinyl to last, don't use a magic eraser. And the areas that you used the magic eraser should be treated with a protectant to help prevent a worse stain that will require more material to be removed to clean.
I use boat bling hot sauce on exterior after I pull off water each time. Shammy it and mist and wipe down with hot sauce. Interior stains easily removed with the boat bling interior. I have used hula boat care products and like the waxes and polish but think the boat bling works a tad bit better and comes in a nicer spray bottle that will last. Hula products come in a cheap small sized bottle. I Have wasted money on babes and wasn't impressed. Think they color water and put odorizer in it and call it boat cleaner!
I can speak with experience on this. Cleaned the crap out of our last boat with a magic eraser - looked great too! Then about two months later the vinyl became brittle and started cracking. Bad deal...
Boat bling hot sauce for wipe down. I actually use a knock off called Zip Mist. I think it is exactly the same stuff. Sort of like Kirkland brand Hot Sauce.
A good coat of every wax I have tried makes whatever you wipe the boat down with work much better. I use collinite and have found it to be great, but it seems that waxing your boat is the best thing you can do to make your exterior wipe down product work better.
For cleaning, I use Malco leather and plastic cleaner or Boat bling vinyl cleaner with a soft brush. All of the interior cleaners I have used work pretty well if you use the brush.
For wipedown of the interior, I use 303 protectant.
I have tried lots of stuff, and like what I am using now the best. I even used 303 mixed with water on the exterior and it works pretty well. A little streaky at first, but it works great, and the gelcoat will shine. I also made my own with distilled water, liquid wax and a touch of vinegar. That worked OK too if you are on a budget.
I'm probably a cheapskate, but for the exterior, I still use a 50/50 vinegar-water solution with a bit of liquid Turtle Wax thrown in. I also have some Boat Bling Hot Sauce and Transom Sauce for spots that don't come out with the vinegar/water (but I've not had to use those much since I went from a mostly black to a mostly white boat). The Transom Sauce tends to leave a bit of a film.
For the interior, after most trips, I just use warm water with a little bit of dish soap (again, probably my cheap side coming out). For spots/stains that need cleaning, I've been using Boat Bling's Vinyl Sauce. I bought some Hula vinyl cleaner, but I haven't had a chance to try it yet.
