Originally posted by JLG
View Post
West Marine Oil Extractor $56.99 - Today Only
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Timmy! View PostIt's a giant mess cleaning that system up, thought this might be a cleaner way of doing things.
EDIT: As for your hill: This pump works so well you can do it in the water, like I do. When it's time to change the oil, just take the stuff with you and do it on the lake at the dock. I am not kidding. Or, pull out of your driveway and do it parked along the side of the street. With this pump it's all of 15 minutes from start to totally, completely done. It will change your life... you'll probably name your next child "MityVac".Last edited by IDBoating; 10-06-2014, 07:42 PM.
LOL! Ok, Ok, I will get one... I wish our lakes were like yours. Our docks are so busy that you can only tie up to them for about 5 minutes. Some lakes have a 15 minute zone. I was able to tie up to one on Sat for 30 minutes and came back and then couldn't get back to my boat because the Marina is closed for the season and someone closed the locked gate that was never supposed to be open in the first place. Luckily I found someone that had an access code so that I could get back to my boat.
On another note, my dealer uses a Jabsco ballast puppy. They have it mounted to the top of a 55 gallon drum on wheels and a 12 volt battery and just roll it to the boat, hook up the hose and turn it on and the oil just goes into the drum.Last edited by Timmy!; 10-06-2014, 08:13 PM.
Besides having to keep the extractor on board while out you don't need to be on a dock. I changed mine while I dropped of my dad and nieces at the beach and came back 15 minutes later.
Using these extractors are awesome. As I said this was my first year ever using one and it sure speeds up the job. Once done I just spray some engine degreaser in the container and down the line, rinse out and put away. I'll just have to look for the part to attach the existing hose off the motor to the extractor hose for even faster/easier changing.Last edited by BCRider; 10-06-2014, 08:16 PM.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by BCRider View PostBesides having to keep the extractor on board while out you don't need to be on a dock. I changed mine while I dropped of my dad and nieces at the beach and came back 15 minutes later.
Originally posted by WABoating View PostOn the lesser model, you just remove the suction hose and it opens up a little pour spout. Then just pour into your disposal container.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Stingreye View PostI have been warned not use the plastic hose in the trans but I use it anyway. Anyone gotten the plastic hose stuck in the trans yet? Am I playing with fire?
Why "no plastic hose"? What else are you going to use, metal? If there's a chance of it getting stuck I would think plastic would be a better option.
Originally posted by WABoating View PostI service my transmission exactly that way and don't have a problem. Interestingly, I only get about half the rated amount of fluid out each time, despite aggressively working that hose all over in there. But I change it every 50 hours, way more often than required, so I figure I'm OK.
Why "no plastic hose"? What else are you going to use, metal? If there's a chance of it getting stuck I would think plastic would be a better option.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
