Hey guys, so as some of you may know I am new to tige and this is my first inboard Vdrive. I came from an I/O where I was able to put an adapter on my engine and connect it to my garden hose (believe they are called engine muffs) and start the boat up at home before hitting the lake to make sure everything is ready to go. Was curious to know how do you do this with inboards? do they make an adapter for it? Is it as simple? All info/products would be great thanks!
How to dry start my Z1
Well look at that, exactly what im looking for. So it works the same way as the I/O muff? Put it over the water intake scoop, turn on hose, and power up the boat?Originally posted by dingleberry View PostMost people call it fake-a-lake. Basically it is a plunger with a hose connection on it and a telescoping handle. You can buy them at most any marine supply store (or make one with hardware parts). It gets wedged under the boat to cover the water intake scoop.
LOL I was just backing you up!Originally posted by dingleberry View PostHey now - I did mention that he could make his own with hardware parts.
And did you really have to use a blue plunger on yours? Doesn't match either of your boats
Definitly, my homeade fake a lake has a black rubber plunger, that would look much better against your black hull, paint the handle red and your in business.Originally posted by Iwndr View PostMaybe I should upgrade.....
Might even win PW of the month again
I will definitely take your comments under consideration.Originally posted by Ewok View PostDefinitly, my homeade fake a lake has a black rubber plunger, that would look much better against your black hull, paint the handle red and your in business.
