I picked up a b&m 70268 super cooler. However I haven't installed it yet. My first big trip is in June so I need it done by then.
The plate fin style seem to be reported as the best. Otherwise they are all about the same. It just comes down to surface area and air flow.
As for your other query, the heat comes from friction. The more weight you are pulling, the more friction, hence heat. You can run a bit hotter so long as your fluid gets changed somewhat more frequently.
