Hi all. So I went out to check on the boat in storage this weekend, and I noticed the TAPS plate was hanging down. For reference, the boat is a 2004 22v. The hydraulic ram is still attached to the boat with the black pin at the top, what it looks like is the black plastic piece (that is attached to the stainless plate) that slides into the hollow metal rod simply fell out. The boat hasn’t moved, and there is no sign of hardware that fell to the ground, also I don’t see a hole where a pin would slide through these two pieces. Further, if a pin slid through these two pieces, I don’t know how the plate would articulate up and down. What it looks like is the plastic piece slides into the hollow portion of the ram and is then crimped. I’m guessing that since the temperature dropped to the mid-20’s the materials contracted and the fit was no longer tight.
The question is, has anyone ever seen an issue like this? Is it repairable or does it require a brand new unit?
Thanks!!
Thanks!!
