Originally posted by gibbs114
View Post
Build Quality
Standard prop is fine too, again unless you are going to run an unreal amount of weight.
I guess a question to ask is what are you planning to do with the boat? Surf or wake board, or both. How heavy are you going to weight it?
Then you should be fine. You are going to want to run the 930 lbs Custom Tige Enzo style sacs in there. Fly High W005-P and W005-STB. They are made to plug right into the existing hoses for the rear surf sacs.
