Gotta leave my boat outside for a few months over the winter. Can you fold down the alpha Z tower and then put the cover over top? Just not sure if it fits. Any other tips or tricks you do. Boats usually in a garage but with the move its not possible and its only for 3-4 months. Winter temp where we are going doesnt get much below zero and not alot of snow. Dont feel like shrink wrapping unless its a must as its a 300 dollar plus hit. Thanks
tower and storing
I tried it and it won't work at all with the stock cover. The cover fits to tight no room for it. We also considered putting a second larger cover over the stock cover and then the folded tower. Problem with this is the Alpha folds inside the boat and that doesn't work with the cover on. I tried putting a 2x6 across the boat for the tower to sit on but then it sits up really high and you'd need a huge cover to go over the top.
Shrink wrap is worth the $300 IMO to protect the boat right.
Tigé Junkie- May 2013
- 919
- Central MN
What about covering the boat and then pick up some pallet wrap and wrap the tower by itself? This would also allow you to wrap the cover tight around the tower to prevent moisture/snow/dust/dirt from getting in around the tower. Just an idea.
At the end of the day I would X2 boardman74Originally posted by boardman74 View PostShrink wrap is worth the $300 IMO to protect the boat right."I think I am pretty smart for an idiot"
If you don't want to shrink wrap I would keep the tower up, put on the regular cover and use some ropes tied to the tower and trailer and quality heavy duty tarps with a steep angle to keep the snow off. It's no subsitiute for a professional shrink wrap job but thats the best I can think of.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
These boats are shipped to the dealers with thick plastic covers that cover the whole boat, including the tower in a lowered position. If you are near a dealer, you can ask if he has kept any of those or see if he has any shipments coming in that he can keep one from. If you're not close to a dealer or they don't have one, maybe Tige would send you one. I imagine it would be cheaper than shrink wrap. I used one from my dealer when I had to store my boat with the tower lowered. It worked pretty well on a temporary basis.
I paid my dealer the $300 for a towing cover when I moved this spring. it's plastic, secured by string and shrinkwrapped to the boat. nice thing is that I was real careful when I removed it and now have a cover that will go over the boat when the tower is down that should get 2-3 more seasons of storage in the garage out of it to keep the dust off.
I'd spend the money, make sure it's a removable cover and now when you store in the winter if you have a garage that you can't put the tower up there's a way to keep the winter dust out..2012 22ve.. RIP 4/17
2014 Z3.. Surf away
