Adevine87 ran my rca's directly across in front of the gas tank to the port locker on my z1. I'm sure your z3 will be similar in that aspect. We pulled the cover in front of the fuse panel and then fished them across. It beats going around the transom or to the bow in my opinion.
Mounting WS420SQ under dash on Z3 ?
The wire kit includes color coded RCA ends, making it easier to connect the corresponding ends to both the SW-420 and respective amp inputs. The kit also includes a 3-conductor power harness. 1 wire is for the WS-420 B+, one for the GND and the 3rd for the turn-on circuit.Originally posted by Travism View PostOk guys
Which way are you running the wires from under the dash starboard side over to the amps in the port locker ?
I purchased the wet wire kit with the ws420 and assumed there would be some good instructions along with it.
Any tips for wiring this thing up ? Really would like to get it in before I head out for holidays on Friday !
Thanks !
Its crucial that all the stereo gear share the same battery source, so terminate the B+ and GND to one of the amps or the distribution blocks.
Every boat is built differently and every install is unique, so how one specifically runs cables and wires is going to very. With the Tige, you should be able to drop down in to the bilge on the helm side and come back up into the port locker, then run up the wall and over the ceiling to the amp install area.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
