Hello everyone I need to rebuild the oil bath bearing assembly. I have a extreme trailer, went to their site no parts section there, are they a standard marine item? I was going to try west marine, I'am here in So Cal, any help would be appreciated. Thx's
0il bath bearing
if your really set... use pacific trailers.. they are based in chino CA! I usually get all my trailer parts from them! CALL and ask for joe in parts.. he should be able to help you out!Originally posted by foxfam312 View PostHello everyone I need to rebuild the oil bath bearing assembly. I have a extreme trailer, went to their site no parts section there, are they a standard marine item? I was going to try west marine, I'am here in So Cal, any help would be appreciated. Thx's
http://www.pacifictrailers.com/2011 Tigé RZ4
www.re-viveupholstery.com
Call UFP, they most likely are the manufacturer of your axles. They can help you out with getting bearing buddies.Originally posted by foxfam312 View PostHello everyone I need to rebuild the oil bath bearing assembly. I have a extreme trailer, went to their site no parts section there, are they a standard marine item? I was going to try west marine, I'am here in So Cal, any help would be appreciated. Thx's
ufpnet.com
X2 on UFP
I told them that the brakes were dragging and popped the dust caps off on my Boatmate and they sent me new calipers and everything I needed to rebuild my Oil Bath hubs. Under Warranty
If they are UFP oilbath and braking systems they will stand behind them
Six Roblees is a good resource for Trailer Parts.
They also suggested grease is better than oil for any bearings that are not used daily.
When sitting for extended periods, a portion of the bearing is above the oil surface. With time and moisture, that part will corrode.
X7
http://sixrobblees.com/Last edited by mls6722; 12-13-2012, 02:29 PM.
