I was reading this post and saw where this guy puts roller rockers in his Tige. I was just wondering if any one else tries to get mo power out of their motors?
How many of you try to get more hp out of your motors?
Not many. Not many at all. Wicked put the roller rocker set up in. He's a pretty handy fella though. I thought somebody put stroker motor in their's. Can't remember who now.
Mine is bone stock except for good quality plugs & wires, filters & fluids. It's kept clean and dry and warm when its not on the water. Starts every time and does everything I need. Not sure I want to mess with it. If for some reason it gave up the ghost, I might put something a bit hotter in it.You'll get your chance, smart guy.
This may be it:
Originally posted by bigdaddy_houseboater View PostI had my issues early (20 hours) when I blew up a motor that alrmed too late. It's all good.. I built a bad mofo 383... 405 hp.
My 20i runs 47-48 mph... and has seen 51 with the bimini down and a light load.
Im cool with mine.
I haven't done anything to our current boat's motor...wife won't let me. I cracked a 265hp v8 due to a freeze and dropped in a 300hp motor as the replacement. It was bored, stroked and had different heads. Of course it was a ton better, aside from that, never did much tinkering with the engine.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
My PCM EX343 is bone stock and will stay that way. I even buy PCM's own labeled oil and fuel filters. LOF and tranny fluid every 50 hours. All fuel filters every Fall. I keep a written log of everything that happens to the boat and drivetrain with hours down to the tenth.
Like NickyPoo said, it's totally reliable - and I'm caring for it like I want it to stay that way forever, because I do.
Originally posted by WABoating View PostMy PCM EX343 is bone stock and will stay that way. I even buy PCM's own labeled oil and fuel filters. LOF and tranny fluid every 50 hours. All fuel filters every Fall. I keep a written log of everything that happens to the boat and drivetrain with hours down to the tenth.
Like NickyPoo said, it's totally reliable - and I'm caring for it like I want it to stay that way forever, because I do.You'll get your chance, smart guy.
Originally posted by skippabcool View PostI believe BigDaddy_Houseboat had motor issues that were not resolved so he ended up putting the stroker in his. I could be wrong.
I'm definitely a fan of the stroker motor. Torque motor. Good marine application.You'll get your chance, smart guy.
I've modded almost every vehicle i've ever owned, but have left both boats bone stock.. something about the reliability of a stock motor and not having to worry about getting a tow back to the dock..
being somewhat new to boating in the last 5 years, I found that a prop upgrade on my last boat did more than any engine upgrade ever could have..2012 22ve.. RIP 4/17
2014 Z3.. Surf away
Originally posted by jzts0214 View PostI was reading this post and saw where this guy puts roller rockers in his Tige. I was just wondering if any one else tries to get mo power out of their motors?
I will never modify my motor. Marine motors are pretty maxed out when they come from the factory. The difference between the MP 340 and the next higher hp. Probably about everything, pistons, cams, crank, etc. It's not really worth it.2007 RZ2 Marine power 340hp Custom ballast
Tundra Crewmax 5.7L
