Just had the install done and these DeepSea 12 LED on-hull lights are sweet. Strobe and dimmer and they are bright. The water at Lake of the Ozarks isn't the clearest but these leds light up the water.
New DeepSea 12 LED On-Hull SeaLites
Quick search came up with $850. Only 3 colors and I do not see any info about thier output. Will dig deeper laterMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Junior Member- Jul 2006
- 192
- osage beach, mo
- 06 Tige 22v Riders Edition, Black & Yellow, with a loud stereo and custome Tige bimini
there is all the tech info on the site.. go to deepsee.com then go to the products... go to 12 led on hull...click on the spec sheet and there you go
Light Specifications
MECHANICAL
Housing Material: High performance polymer
Pressure Tested To: 25 PSI
Size:
Thickness:
Diameter:
0.64 in. (1.63 cm)
4.99 in. (12.67 cm)
Weight (cable not included): 0.55 lb. (0.25 kg)
Lens: High performance polymer
Cable Length: 15’ (4.57 m)
Hole size through transom for cable: 5/8” (16 mm)
LAMP
Type: LED (White, Blue, or Green)
Rated Average Life: 50,000 hours
Color Temperature: 5,000º K
Beam Angle: 30º
OPERATING
Warm Up / Re-strike Time: Instantaneous
Minimum Operating Temperature: -22° F (-30° C)
Strobe Feature Frequency / Duty Cycle: 5 Hz / 70%
ELECTRICAL
Input Voltage: 10-32 VDC
Input Current: 2.0A at 12 VDC Typical
Input Power: 27 Watts Maximum
Strobe Input: Active ≥2.0 VDC
In-active ≤0.3 VDC
Dimming Input: 50K ohm 10 turn potentiometer or 0 to 5 VDC
(max 32 VDC)
- 192
- osage beach, mo
you can call them (858) 576-1261 X 307 and talk with Erik Goodin or contact him by email erik_goodin@deepsea.com
tell him Craig Trudelle told you about the products
thanks
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
Looks like it is not the simple cheap light I was hoping for. For these things being simple chinese LED's, they seem to cost an awfully lot of money.Originally posted by chpthril View PostQuick search came up with $850. Only 3 colors and I do not see any info about thier output. Will dig deeper later
I didn't put more than $750 as an option, CHP.
There is not a list of how many Lumens they are on that spec sheet, and that is the brightness measure we are looking for.Be excellent to one another.
- 192
- osage beach, mo
First off these are not cheap Chinese LEDs DeepSea has been an innovator in the underwater lighting and camera equipment
DeepSea is a world leading manufacturer of underwater lights for deep ocean exploration and recreational boating. Since 1983, DeepSea has provided lights for marine research activities to the furthest ocean depths, as well as those that work 24 hours a day on Remote Operated Vehicles in offshore oil fields the world over.
DeepSea's years of specialized experience and expertise were used to develop the most advanced underwater lights for boats. In 2003, DeepSea designed the popular Thru-Hull SeaLite®, which earned a reputation as THE underwater boat light to have. In 2008, DeepSea revolutionized underwater lighting again, unveiling cutting edge LED underwater lights for boats. This next generation of underwater LED boat lights, utilizing* high performance CREE LEDs,*includes innovative new features such as built-in strobing and dimming. DeepSea has perfected LED boat lights for underwater use and offers both thru-hull lights and surface mount underwater boat lights.
Underwater yacht lights are great fishing lights, ideal for observing sea life, act as a beacon for night diving, and enhance the beauty of boats. Whether mounting the LED underwater light in your boat's transom or hull (or both), it's comforting to have the peace of mind in knowing your LED underwater light was designed by a company with over 25 years experience building high quality lights for the harshest subsea environments.
DeepSea Power & Light - The Most Advanced Underwater Lights
- 192
- osage beach, mo
If you want to know about the lumen output call the company and ask question they are very good with customer service
Remember you want quality you have to pay for it. I would be glad to put these lights up against any of the others- shadow caster, ocean led or any of the other companies Not putting down or bashing the other companies but i love the choice i made and like Tige owners i am loyal to products that perform and have good customer service
