Has anyone fit a Acme 1235 prop on a 22V? I spoke with Acme today and they guy I talked to said there's no way a 1235 would fit without being too close to the hull. Is this true? Thanks!
Acme 1235 on a 22V
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
One of the changes between the V and Ve is the angle of the shaft. The V does sit a little closer to the hull. Whether the small change in diameter would make any difference is a good question.
The diameter of the 1235 is only going to be 1 inch different than the 537 that is on there now. I am not sure that 1/2 inch closer to the hull is really going to be a problem. I would climb under the boat and check that the prop you have now is the 537 that is 13.5". The 1235 is 14.5".Be excellent to one another.
If the clearance of the 1235 is an issue, then I would suggest the 1433. 14" DIA x 14.5 pitch. This prop will improve the hole shot and bite, yet has a small diameter increase to offset the RPM increase due to the drop in pitch.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I didn't ride in topaz's boat but, I did surf it. I thought it pulled just fine out of the hole. Also one of the best wakes I've ever seen.Originally posted by topaz surfer View PostI run the 1617 on my 2003 22v with around 2600lbs of ballast and the 5.7 merc and it pulls really well out of the hole. Its a 14" prop and when I was measuring I think a 14.5 would be cutting it really close. Im also at 5000ft. Hope this helps.
They did change the angle between the v and ve. I just put a 1579 on my buddies 2004 22v, which is a 13.5. I had a 1433 on my 23v, and I think my buddy should have got that one as well. I think a 1235 would fit but you would get gelcoat burn from it running to close to the hull. So your best bet would be a 1433.
Thanks nicky that was a fun day. We need to get together again for a surf day. Granted I haven't tried any other props yet but my 1617 was able to pull up a surfer with my 2600lbs of ballast with 8 guys in the boat all averaging 250lbs each.Originally posted by NICKYPOO View PostI didn't ride in topaz's boat but, I did surf it. I thought it pulled just fine out of the hole. Also one of the best wakes I've ever seen.
I'm mostly wakeboarding these days with about 3000lbs, so will the 1433 or 1617 be a huge improvement from the 537 that I currently have? We surf often as well, but the 537 does a decent job with the 1200lbs I use. It's just pretty terrible at getting up to and staying at 23mph with 3000lbs and more than 2 ppl in the boat. I need to do some measurements, but I'm willing to risk gel coat burn under the boat if the 1235 is substantially better than the 1433 or 1617.
With either the 1235 or the 1433, you are dropping 1.5" in pitch. This will improve hole shot over the 16" pitch 537. With both, you are also adding diameter. This increase in surface are helps with speed holding and reduces cavitation.Originally posted by Mogey View PostI'm mostly wakeboarding these days with about 3000lbs, so will the 1433 or 1617 be a huge improvement from the 537 that I currently have? We surf often as well, but the 537 does a decent job with the 1200lbs I use. It's just pretty terrible at getting up to and staying at 23mph with 3000lbs and more than 2 ppl in the boat. I need to do some measurements, but I'm willing to risk gel coat burn under the boat if the 1235 is substantially better than the 1433 or 1617.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Acme may let you buy the prop and return it if you don't like it. But they usually charge full list price for that service. CHPthrl may be able to get it for a little less. I would contact him, and I would be willing to bet you will get the right prop the first time around without worrying about a return.Originally posted by Mogey View PostI'm mostly wakeboarding these days with about 3000lbs, so will the 1433 or 1617 be a huge improvement from the 537 that I currently have? We surf often as well, but the 537 does a decent job with the 1200lbs I use. It's just pretty terrible at getting up to and staying at 23mph with 3000lbs and more than 2 ppl in the boat. I need to do some measurements, but I'm willing to risk gel coat burn under the boat if the 1235 is substantially better than the 1433 or 1617.Be excellent to one another.
