Source for mono leaf spring for 1998 extreme trailer?
    So my boat is sitting 300 miles away with a broken leaf spring. Anybody know where I can find a single leaf spring replacement? Of course everything I can find are multi spring packs while mine has a single leaf style spring.
    I'm sure I'm not the first person to break one of theses. Anyone know a source for them?
    Thanks. Bakes
    Momo leaf are harder to find. The best place to look would be a Trailer house parts store. Most of the old trailer houses had those springs. Or the internet. You could also spend the extra $ and buy all 4 springs an convert it to the multi pack springs. Trailer will pull better and ride smoother too. Get the springs for 3500# axles which are 1750# each should run roughly $30-40 per spring pack. Just need to measure lenght of the spring and bolt size.
      http://www.truckspring.com/trailer-p...e-mts-115.aspx
        Well...turns out they are a little hard to come by. RAther than drag this out a few weeks with my boat/trailer sitting out in the elements and still not reset from the trip...I am just having them swap out the rear ones with 3 leaf pack springs on both sides. Will likely convert the other 2 in a few weeks as well.
        Anyways, my recommendation is to swap them out rather than replace the mono-springs. I was really lucky the axle did not dislocate itself at speed since the when the monospring broke...so did the structural support locating the axle. Much less likely to happen on a triple spring pack.
        Going to pick it up on saturday...hopefully all will be well
          Good luck, I think you will be much happier with the way the multi packs ride/pull too.
