Morning all... My wife and I have a 2008 20V and just started surfing this weekend. We obviously need more weight and need some suggestions. I don't have any bags at all in the boat. Any suggestions on brand, weight, location placement, good websites would all be appreciated. Thanks you and have a great day.
Ballast recommendations
The best value sac is the Fly High W719 Jumbo Surf sac. Its rated at 1100Lbs full and measures 24x25x50. With the dimensions of the 20V locker, I think you should see around 1000 lbs
in the rear locker.
This sac comes with the needed fittings that will mate with the W709 pump kit, or can easily be plumbed in if you wanted an automated system.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
20V owners will be able to comment on thier exact ballast setup in regards to what sacs, how much weight and placement, as well speed and TAPS setting, but a single sac in the rear locker on your surf side will give you a great starting point.Originally posted by Cubacheski View PostThank you for the suggestion... So do I just need a single sac on the side we surf and leave the other storage compartment for actual storage ?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
