Does anyone know if the WetSounds speakers are under the initial boat warranty? I have had the boat for almost 3 months and I noticed this past weekend that my subwoofer under the helm has a cut in it! Not happy ...
Is Wet Sounds under warranty?
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
If the cut appears to be the result of something hitting it, then I would highly doubt it. Unless you could get them to believe it came and was installed like that? If you mean a spontaneous separation, then I think you would get it covered, no questions asked.Be excellent to one another.
Typically, physical damage to a speaker (tear, cut, hole, etc) is not covered under warranty unless it looks like it is a defect where it wasn't assembled properly or the adhesive failed that bonds the surround to the cone.
If you think it was damaged while it was being installed at the factory then I'd talk to your Tige dealer or call Harvey at Tige. I'm sure they will take care of it.
Pics?
I sure hope it was spontaneous/immaculate separation, otherwise....come on man!Originally posted by talltigeguy View PostIf the cut appears to be the result of something hitting it, then I would highly doubt it. Unless you could get them to believe it came and was installed like that? If you mean a spontaneous separation, then I think you would get it covered, no questions asked.
