Boy Ive been posting about lots of problems lol at least they are all little things and easy to fix so far my next problem is when we were out on the water just cruising around the bilge would fill with water not to quick, but when we were surfing it would fill really quick I had to turn the pump on every 10-15 min and it would pump for a while to empty it out I crawled under the boat it all looks good everything is tight no holes yes the plug at the back was in could it be the drive shaft seal? is there a way to test it? could it be anything else? And when checking tranny oil is it like a car with the engine running?
water in the bilge
I can't say mine is dry but there is usually never more than a cup or two of water. (unless I take a wave over the bow) which happens on occasion. You might also lift the hatch with the enging running and see if you have any leaks in the cooling system i.e. raw water pick up hoses or other hoses.
Take a look at the shaft packing area while the boat is in gear. I've seen that put water in the boat quickly. Might just need to be tightened a bit.
Here is something to get you started.
http://www.tigeowners.com/forum/show...+shaft+packing
Just a possibility I'd look into.
I looked at the link and I took a pic of my stuffing box but its different then the one in the pics on that link mine doesnt have the big nut its just a smooth donut? and its going to be a biatch to get to! can mine be tightened? Im trying to down load a pic of it but when ever I try and put pics on here it never works?Originally posted by bryancm View PostTake a look at the shaft packing area while the boat is in gear. I've seen that put water in the boat quickly. Might just need to be tightened a bit.
well the shaft seal was good the ballast stuff was all good and after a while of searching I found the problem YAY!!!! Could hve been close, the clamps for the intake hose at the hull of the boat were super loose it didnt leak to bad at idle but when under way with weight in the boat WOW it leaked good I can only imagine if it popped off the trouble I would of had.
