Any ideas on glove compartment cover?
    As you can see, the plastic where my hinge attaches has broken off. I want something a little more classier and permanent than the duct tape that I have been using? Any ideas?
    See if Tanner will scavenge the one off his road rash boat. It certainly sounds like it's totaled anyway. It might not fit, but it's worth a shot?
      buy a plastic welder and fix it.. Simple
        I used part of my carbon fiber arrows and some epoxy. Then loosen the hinges up so it doesn't break again
          Thanks guys for the great ideas. I tried to find a plastic welder around town and I was going to try reinforce it with aluminum. But I could only find a fiberglass repair kit. But I think that will work well to build it up and have it be strong enough to not break again. I will let you know how it turns out.
            Just use some ply wood hahaha
              I ended up fiberglassing in a hack saw blade and fixed a small crack. I am going to drill the holes in it for the hinge and then paint the inside black.
