Anyone ever have any issues with there Navigation lights not working? The switch on my dash lights up when I turn them on, but nothing works.
Navigation Lights
Switch has power, so the problem is from the switch out. Do the helm lights illuminate? Is it just the front NAV or is the anchor out as well? Could be as simple as bulbs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If it's my bulbs, do I replace them from the outside of the boat or is there a way to replace them from inside the hull?Originally posted by chpthril View PostSwitch has power, so the problem is from the switch out. Do the helm lights illuminate? Is it just the front NAV or is the anchor out as well? Could be as simple as bulbs.
Is there a row of breakers on your dash? with ne labeled NAV lights? If so, try reseting it.Originally posted by lalhc View PostNothing illuminates. Is there a fuse somewhere in between?
Could be either way. Of its a top mounted NAV light, the housing may come off. If they are side mounted, I bet the socket pops out from the back of the light housing.Originally posted by lalhc View PostIf it's my bulbs, do I replace them from the outside of the boat or is there a way to replace them from inside the hull?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I just purchased this boat used and I'm still becoming familiar with it. So the small round rubber buttons below the Nav switch is the breaker? When I press it, it feels like it's not doing anything.Originally posted by chpthril View PostIs there a row of breakers on your dash? with ne labeled NAV lights? If so, try reseting it.
My Nav lights are side mounted.
Yes, thats the breaker. As Skippa notes, it could be a bad breaker. If it was tripped, it would be extended out and should click when pushed in and resets. One other possibility is that your boat has the breaker module assembly that was used in the early 2000's models. This breaker modules are known to go bad, but usually every accessory on that module stops working. A 12V test light would be an asset in this case to chase down where the power stops.Originally posted by lalhc View PostI just purchased this boat used and I'm still becoming familiar with it. So the small round rubber buttons below the Nav switch is the breaker? When I press it, it feels like it's not doing anything.
My Nav lights are side mounted.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
