Took out the 2010 RZ2 for the first time this year yesterday. Cold, it was very cold. Anyhow, couple of things. I had the latest version updated to the touch and it did not rectify the issue I'm having with my ballast system. Anytime I change key positions (finish a surf set and kill the boat, have the key in aux position and start the boat) the ballast shows as empty. So of course when I select my profile, the boat wants to fill the ballast sacs to their setting.
2). For the guys with the big sacs, I'm running 1000 lb sac starboard and 400 lb sac on the starboard bench behind the driver. We had a good tilt going, but the bag was emptying itself. I believe it is due to having a short length of hose connected to the vent, so here is my question. Would my best bet be to run the hose from one locker to the other (port side rear to starboard side rear) and vice versa to rectify this issue? I lost a good 8 inches off the top of the sac.
Other minor issues were chrome (or should I say plastic) piece of steering wheel fell off. This is the second steering wheel I've had issues with, first one was peeling apart. Needless to say I'm not a fan of the stock steering wheel. Maybe Tige will let me upgrade this time around.
Also, I noticed that the taps and the rpm gauges look foggy?? No condensation, but hard to read when the sun is out. Speed gauge looks fine.
