which ones do you like? and what length?
bungee dock lines and bumpers
I use a 4' Straight line bungee from my ski pole to the dock cleat. The SL bungees have nice built in plastic clips that also allow you to easily attach to ring cleats or if the cleats are too large.
I then use normal lines if I plan on leaving the boat more than a few minutes. Or if there is current/wind.
I use these bumpers as my boat is old school with an uber low freeboard.
http://www.overtons.com/modperl/prod...1&merchID=4006
I have a direct drive boat with motor in the middle of the boat and the ski pylon (pole) in front of the motor (I don't have a tower). My ski pole is pretty close to the direct middle of the boat, so it holes pretty well by itself.
I'm not sure what boat you have, but if it has a tower you may want a shorter line, and wrap it around the tower and down to the cleat. Each dock is different, that is why I also always carry 4 normal dock lines too.
Bungee lines are meant for long term docking or in high current or windy situations, so make sure you get normal lines also.
Originally posted by Joeprunc View PostI use a 4' Straight line bungee from my ski pole to the dock cleat. The SL bungees have nice built in plastic clips that also allow you to easily attach to ring cleats or if the cleats are too large.
I never knew they made something like this until now.
This is the coolest thing I have found! They work awesome for lots of things...
http://looprope.com/
Thanks for the reminder on these. I saw them referenced on TO last season and meant to get a few but never got around to it. Just ordered some and look forward to checking them out.Originally posted by wired1236 View PostThis is the coolest thing I have found! They work awesome for lots of things...
Sure - we just got them from the boat show this year so we haven't really put them to good use yet but look forward to using them for a lot of things.Originally posted by Duncan View PostThanks for the reminder on these. I saw them referenced on TO last season and meant to get a few but never got around to it. Just ordered some and look forward to checking them out.
and thoughts on something like this for temporary docking
thinking I can double it up with a bumper
I had a dock mate line from overtons, but after being on a friends boat and using the straight line (with the little plastic clip). I bought a SL and my dockmate has not been used in a year.
A lot of marinas, ski courses, bars, neighbors docks have different cleats, different size cleats, or none at all. I always had to get a little creative to attach the dockmate to some of the odd ball cleats (rings, large cleats where the loop wouldn't fit around, ski courses or neighbors that just have a hole in the dock).
The Dockmate is nice, but the SL clip makes temp docking much easier.
