I am a long time boater but new to inboards. Looking at a 2010 Z1and the owner says it is 275 HP. Is that possible as Tige says smallest motor is 300HP? Would a 275 HP motor be too small for this boat. What does the extra HP give you in a inboard. Top speed doesn't really seem to be the consideration. Thx!
2010 Z1 Motor Size Too Small?
It is strange that an owner would down grade from stock motor unless cost was the issue and the savings for a 5.0 vs the 5.7Originally posted by Iwndr View Postthe PCM ProSport 5.0L MPI 275hp was an option in 2010
made the initial sale.
I test drove the older 20V with the 300 Hp MP motor VS the 340HP 5.7 motor and if any time deep water slalom skiing is done with 275hp a 200lb skier is goint to have to work to get up. Yhr torque of the bigger motor is evident when pulling slalom skiers.
I would see if you can find one with the 5.7L PCM. You may have to spend more even on used boats but the reponse of the 5.7L is a lot better than the 5.0L with a loaded boat. With 1 person in the boat it will feel responsive with the 5.0L as you put more weight in boat the torque of the 5.7L will handle the load IMO:
Jave a good day
Taxman got all the money :(
I have an 09 Z1 with the 343 and it is great with full factory ballast, them some more and 6-7 people.
If you don't care about top speed, and the price is right, you could always regear it (prop with diferent pitch). But you may also have issues for resale later down the road.Friends don't let friends POWERTURN
