Originally posted by Timmy!
View Post
I got a gripe with Tige!
350? try 250!Originally posted by 2thdoc01 View PostHoustonshark......Whare did you get a 3.75 rate? Whats the term?
I think im just gunna say screw it and get it all minus the bags...id want 2 400 lb bags up front and something bigger than 350 in the rear.....
Standard is 900lbs set up as follows
Bow - Single U-shape 400lbs
Rear - 500 lbs, 250 each side
Surf set up
bow - Single U-shape 400lbs
Rear 1200lbs, 600 each side.
Pro-
Bow - two single 400's
Rear - 600 each side (1200lbs)
MCT Credit Union in Bridge City, TX (409) 735-8777. Ask for Christina Sterling (she's the branch manager) and let her know you were referred by TJ Morgan.Originally posted by 2thdoc01 View PostHoustonshark......Whare did you get a 3.75 rate? Whats the term?
I financed it for 7 years and put 10% down. I don't think we needed to put any money down, other than to order it at my dealer. They really don't like doing terms much longer than that but they did say they would do 8-10yrs for 4.25%.
I believe the custom sac is 750.You could check with chpthril on that as he is the Stereo and Ballast expert on this site.Originally posted by 2thdoc01 View PostRobert....Yes! Exactly....I was wondering if I could get a 750 lb sac in the rear lockers.....I had a 750 in my vride and it worked good, although the RZ2 looks like the rear lockers are a bit smaller....
Houstonshark...good deal....I have 20% downI do all my own stunt work. hey ya'll watch dis.
The W705 750lb sac is 50" long and 20" high, so some of it does extend past the front of the storage. Due to this, it will not fill to capacity, but I fell its about 650lbs.Originally posted by 2thdoc01 View PostRobert....Yes! Exactly....I was wondering if I could get a 750 lb sac in the rear lockers.....I had a 750 in my vride and it worked good, although the RZ2 looks like the rear lockers are a bit smaller....
Houstonshark...good deal....I have 20% downMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
In an RZ2, the port fills to about 1200 and the starboard fills to 1000+. A little less in the RZR as its not as wide.Originally posted by 2thdoc01 View PostHow big are the custom sacs?
Do they have the little retainer clips on them like the factory bags?
Yes, they come with the anchors. Its a 15 minute Plug-n-Play swapMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
