How many quarts should it take? I have a 2001 22I. With a 350Mercruiser I believe. What is the weight of the oil? Same as our Tahoe? Thanks.
Oil Change...
Search for the oil change threads and look for posts by tigeowner.com user TRD. Hes put together an xls with just about every bit of service info on the Merc.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If it is the 350 mag/mpi, will say on the engine cover...Originally posted by Tstick333 View PostHow many quarts should it take? I have a 2001 22I. With a 350Mercruiser I believe. What is the weight of the oil? Same as our Tahoe? Thanks.
Mine takes 4.5 quarts with an oil and filter change.
I run mercruiser 25/40 synthetic blend.
Definitely do not run "what is in the tahoe" as the marine oil is blended with special inhibitors that auto oil is not.Boating Lake Mead since 2000
