I had thought about the center support which might be the best way to to. I want this thing to be rigid mounted so that it cant rattle around or come loose is why I am going to stay with my grab pieces vs the hooks. Just like my boat I want this thing to look and perform as trick as possible. Thanks for the input. I know cost is not cheap but just the aluminum and stainless steel fasteners is expensive.
Custom step for TIGE boats any interest???
RPM - where is the hull stress occurring? Looking at my pics in the attached link, you think my 2 added bolts (tow ring) and reinforcement are enough?Originally posted by Kimber View PostI would actually prefer to have it as is - with no finish. See the link below showing my grab handle with tow ring. I have a guy that has powdercoated my handle (and many other things on the boat), and I would like the step to match.
http://www.tigeowners.com/forum/show...t=14246&page=2
RPM - how much for the step as is? I still would like to see pics of it mounted. How do you prevent it from spinning while clamped to the bar? Think I would still be able to use my tow ring?
Tigé Jedi- Jul 2010
- 4274
- TN USA
Anodizing really just thickens the oxide layer that naturally forms on aluminum. Since stainless and aluminum are definitely subject to galvanic corrosion, I would think anodizing might "slow" but would not "prevent" galvanic corrosion. I'd try to separate them with something nonconductive, use nylon/delrin washers, etc.Originally posted by GUY_RPM View PostI am using a stainless steel washer, not sure but I would not think the stainless steel would corrode if touching anodized aluminum?
KemberOriginally posted by Kimber View PostRPM - where is the hull stress occurring? Looking at my pics in the attached link, you think my 2 added bolts (tow ring) and reinforcement are enough?
I think yours will be ok with the added bolts and beefed up hull. I am making some minor changes and will post pictures soon.
Just keepin it real in the bluegrass state. You are very close to where I boat often and store my boat in Henderson. Thanks for all your comments. The only color I am going to offer the Seadek in is grey because that color will go with any boat. The only problem with raw aluminum with no coating is everytime you touch it you will get grey chalky crap on your hands that you will be dragging in your boat.Originally posted by ajholt7 View PostNice work for a Kentuckian.
No, when I go out in Henderson I put in at the city ramp. If the step interest you just let me know and you can stop by and check it out on the boat. I am working on a center support that hopefully will be complete next week then all that will be left to do is get it anodized, you will see it was powdercoated in the pictures but I am not happy with the powdercoating and intend to remove it. My boat is stored in the area of town out by Gibbs Die Casting.Originally posted by ajholt7 View PostI drive through Henderson everyday. I guess you boat on the Ohio. Do you use Hayes boat ramp?
[QUOTE=Kimber;561108]I would actually prefer to have it as is - with no finish. See the link below showing my grab handle with tow ring. I have a guy that has powdercoated my handle (and many other things on the boat), and I would like the step to match.
Kimber
After looking at your pictures I would like to know what the white board is that was used to beef up your hull? I was thinking of using a material called UHMW, it is a hard plastic but not so hard that it would not form to whatever it was pulled into. I would also like to know what the purple stuff is that is oozing out from behind the board(between the board and the fiberglass), is it like liquid nails or is it a silicone?
