Looking for a bit of advice
I have an 08 RZ4, the bilge is working in manual but not automatically, its a rulemate 500.
I found a replacement rulemate 500 (oval shaped) but its twice the size, also found a automatic rule 500 (circular shaped) which is similar size, as shown, below, no float switch
I have stripped the old pump down and cleaned it, but still didnt work on auto. Few issues that I wanted a bit of advice on are :
The existing pump is behind the engine, real awkward location plus due to the hull shape this is a high point in the hull, if any water is in the hull it washes back and then fore and doesnt get picked up by the bilge, I want to move it to a lower position, between the gear box and the fuel tank, the floor is removable so its easy access and water sits here
Can I screw the new pump into the hull (short screws) at this location or should I glue it in
Where is the in-line fuse on the bilge pump? the wiring disappears under the bulkhead behind the ballast tanks and I have no idea where it goes?
I am planning to joint the wiring at this location and run it to the new pump location and same with the hose?
any thoughts or help would be appreciated?
This has come about as I am taking on a bit of water, I am in the process of checking, tightening all the through hull connections and intakes to resolve this at the moment
