I have a 2011 RZR (previously had a 2008 20i) I noticed that Tige has not improved on (until 2012!) the 2 small bolts that lock the swim platform in place. I have loc-tighted them numerous times but they keep falling out into the lake! Any one have a solution to this problem? I know Tige has completely redesigned the swim platform brackets for 2012 but that does not help me!
Swim Platform bolts at the bottom of the lake!
What bolt? Ive only ever seen Tige use a clevis pin.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
These boats are transported to the dealers with the platforms in the boat. Sounds like the pin's safety latch is not getting engaged, or is getting bent, when the boats are rigged upon delivery.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I've got the same problem. Dealer added two bolts on the very bottom of the swim platform mount to quiet the rattles and tighten everything up. Did a great job, but noticed they were a little loose before my last trip so I put some loc-tite on them and tightened them up. After a full day or two on the water, they had wiggled loose. I didn't lose them over a 4-5 day trip, but they were on their way. ~50% of our time was spent surfing, so I suppose that it would be a little harder on the bolts.
Love to hear a solution to this.
Don't know what else you could do.
I've tightend up mine a few times already when I notice a lot of play. It's just to become standard, maybe a little thread tape or RED loctite will help keep the bolts up there. I'd hate to overtighten them and strip the platform frame threads, then you'll really have a problem.2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
Is this the pin that you guys are losing and/or having a bolt put in its place? Is a ny-lock nut being used on the bolt or is the bolt being threaded in to the bracket somehow? If thats the case, I dont think it will sure the rattle because those surfaces arent meant to be clamped together. Thats why loctite wont work either.
http://www.tigeowners.com/forum/show...0&postcount=11Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
No. It is the bolt that is threaded into the bottom of the platform's brackets. As you screw it in it forces the platform up putting tension on the pins and bracket. This stops the swim platform from rattling while at idle. Or when waves hit the back of the boat the platform will move up and down. The basically bolts tighten everything up.Originally posted by chpthril View PostIs this the pin that you guys are losing and/or having a bolt put in its place? Is a ny-lock nut being used on the bolt or is the bolt being threaded in to the bracket somehow? If thats the case, I dont think it will sure the rattle because those surfaces arent meant to be clamped together. Thats why loctite wont work either.
http://www.tigeowners.com/forum/show...0&postcount=11"You're rather attractive for a beautiful girl with a great body."
yup those ones, ive lost two sets. oh well no big dealOriginally posted by Booms View PostNo. It is the bolt that is threaded into the bottom of the platform's brackets. As you screw it in it forces the platform up putting tension on the pins and bracket. This stops the swim platform from rattling while at idle. Or when waves hit the back of the boat the platform will move up and down. The basically bolts tighten everything up.
It is obviously a problem. Tige' has completely redesigned the 2012 platform brackets. I'm just wondering what they are going to do for us with 2011 (or any other year) boats to correct this problem. My thought is that the factory should release a "update" to our dealers to replace the brackets.
I've got over 70 hours on my boat and I haven't lost those screws, I dont think they are there to reduce rattle, they are there to level the platform so the cotter pins line up to install the platform. My adjustment screws are not tight but they are in enough to level the platform to make it slightly easier to remove and re-install the platform.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
