Sorry for the cross-post from Maintenance, but I've been fighting this for over an hour, searched all over Google, etc. and cannot figure it out.
I have the belt tensioner fully compressed, but I simply cannot get the belt around everything. I've tried seating it on everything but the tensioner (the manual's suggestion). I've tried seating it on everything but the raw water pump, figuring that since it's smooth it would be easier to slip the belt around it. Nope. There is simply not enough slack to put it on there.
There must be a trick I'm missing. I had an incredibly hard time getting the belt off last Fall for winterization, and now have that original belt plus a brand new PCM in-the-box belt too. Neither one will install. They are the same part number, same length, and are the same distance "too short" to install.
What's the magic trick?
More:
I've reconfirmed that I have the belt tensioner completely compressed. It takes a 15mm socket and I have it turned until it reaches a hard stop. It's not going to move any farther. Yet there is still no way the belt will slip over the last pulley. I've tried the tensioner pulley, the alternator pulley, and the raw water pump pulley (smooth, since it rides the back of the belt). This is with the wrench holding the tensioner strapped, so I have two hands to work with.
I'd swear I have the wrong belt (too short) for this engine, except that it has the correct PCM part number on it. I am bothered by the fact that it was darned near impossible to remove last Fall, though... are there any other adjustments possible beyond just the tensioner's normal spring?
I really want to start the engine today. Any help greatly appreciated.
Thanks!
More:
Thanks!
