I just purchased a 2006 tige 22Ve from a private owner. When we tested the TAPS system it worked fine. Yesterday when we went out to the lake it just made a clicking sound. Any ideas on what it may be? By the way I have been dreaming of this boat for years.
T.A.P.S. not working
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
Welcome to the site, JonG. I hope to see you out at the lake sometime. I am in St. George also. There are a number of us from the area who are active on the site.Originally posted by JonG View PostI just purchased a 2006 tige 22Ve from a private owner. When we tested the TAPS system it worked fine. Yesterday when we went out to the lake it just made a clicking sound. Any ideas on what it may be? By the way I have been dreaming of this boat for years.
Good luck with the TAPS. My buddy is working through the same problem with his 2006 24Ve. His is hydraulic, and has been a complicated troubleshooting problem for him.
Sometimes a gentle tap with a hammer on the piston helps if it is just bound up. Had the boat been sitting for a long time?Be excellent to one another.
Welcome aboard John. I am not sure if yours is hydraulic or not but if so check the pump. I had my pump tip over leaking out the fluid. whiched caused this same type of noise for me.Originally posted by JonG View PostI just purchased a 2006 tige 22Ve from a private owner. When we tested the TAPS system it worked fine. Yesterday when we went out to the lake it just made a clicking sound. Any ideas on what it may be? By the way I have been dreaming of this boat for years.
Yep. My old 21V had the same problem. It clicked and it was the relay. Good luck.Originally posted by dom w. forte View PostTheres a relay under the dash ,that is the most common failure, it is normally located just in front of the shifter in that year and is black about 2 inches square.
Not trying to be argumentative, but those auto shop relays are completely different. I searched high and low for a replacement when mine went bad. I did figure out how I could use 2 auto relays to accomplish the same thing, but in the end it seemed too jerry-rigged on such a big investment. The relays are like $175ish from Tige, so I still haven't replaced mine.Originally posted by bfrank View PostMost auto part stores have these relays.
If I'm wrong, I'd love to have the part # to the relay that will work as the original black box Tige relay works.Other than that, Mrs. Lincoln, how was the play?
