I just got a new drysuit and have never worn one before. looking for a few tips on making sure it works properly. thanks
dry suit
If you get a good suit you can hardly tell its on. When you get in the water pull an air openiing at ur neck and let all the air out. Makes a huge difference. Rode here in colorado in nov this last year water temp was 41 degrees and felt like 70 degree water in the suit.www.1320diesel.com Home of the Fastest Diesels!
Tigé Jedi- Jul 2010
- 4305
- TN USA
If it has latex gaskets on the neck, wrists, and ankles (like our whitewater kayaking drysuits do), they are expensive to replace and should be cared for accordingly. The best procedure is to treat them inside and out with 303 protectant. This will keep them soft and prevent cracking.
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
What he said.Originally posted by WABoating View PostIf it has latex gaskets on the neck, wrists, and ankles (like our whitewater kayaking drysuits do), they are expensive to replace and should be cared for accordingly. The best procedure is to treat them inside and out with 303 protectant. This will keep them soft and prevent cracking.
What model and make of drysuit is it?Be excellent to one another.
Tigé Jedi- Jul 2010
- 4305
- TN USA
You can get latex booties for a drysuit that take the place of the latex ankle gaskets. Then you can wear your choice of footwear, including none at all in wakeboard bindings, etc. These have become very popular in the whitewater community because they give you so many options. If you're rafting, you can wear full watershoes. If you're kayaking, you can wear aquasocks or similar low profile shoes. And if you're playboating, where bow volume is at a premium, you can go without shoes at all while stuffed in your boat.Originally posted by Timmy! View PostSocks for surfing suck, it's hard to feel the board. I wouldn't be able to wear socks for wakeboarding either, my size 15's barely fit in the XXL bindings that I have now. Most wakeboard bindings are neo so that helps out a ton.
Just another option to consider.
