KC to Okoboji is about 800 round trip, I do it every year without incident towing with my 04 Expedition w/5.3 Triton. I don't even feel it back there. I get between 9-11mpg depending on speed and wind direction, but ave close to 70mph. I also pull to Tablerock which is about a 450mi round trip annually.
2007 Trailer HAD oilbath hubs; but one failed in 2009 on a trip from KC to Tablerock lake. Luckily limped to the water and got boat in, then took trailer to a shop to get fixed. Gave whole new axle under warranty with the VAULT bearings. So I had a mixture: one axle has the new VALUT and the other still HAD Oil Bath. One of the OIL bath bearings started to get cloudy and you can't add oil without taking wheel off. I went to a trailer dealer and switched the remaining oil baths to the standard grease bearing buddies hubs. I know they work.
Other thoughts:
Check tires for air pressure and wear patterns.
Make sure you have right lug wrench for trailer wheels--they are different from my truck tires.
Check pressure on your spare
I bring portable chocks when I park it.
Check the heat from the wheels when you get gas (which will be often) and make sure the bolts are snugged up--my alum wheels enable the bolts to loosen.
Am considering a 1200 mile tow to Missisippi River up near Lacrosse this upcoming summer.
Other thoughts:
Of course I am now jinxed.
