What about changing prop from factory to 1235 based on riding that day? Is it just better to get the 1235 or what advantages does the factory prop have? I will have 2000 plus for surfing and generally 2000 with people weight for wakeboarding at most 24 mph.
Question for those using the Acme 1235 prop...
Originally posted by hycosurf View PostJust a thought, it sounds like there is a whole lot of people who have swithed to the 1235 acme. Why shouldn't that just become the stock prop from the factory?
Originally posted by hycosurf View PostWhat about changing prop from factory to 1235 based on riding that day? Is it just better to get the 1235 or what advantages does the factory prop have? I will have 2000 plus for surfing and generally 2000 with people weight for wakeboarding at most 24 mph.
One last thing. Your boat will be much more responsive in the steering with the 1235 as another side benifit also.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by evil0ne View PostWhy isn't a "K&N" stock from the factory? Manufacturers make decisions based on pleasing the masses. If you want to upgrade you have a decent spare for a rainy day.GO BIG!!
Originally posted by hycosurf View PostI actually will have two spares if I get the 1235. I had a spare from the boat I traded, identical prop. How much top end is lost? And what is the fuel comparison? The boat now runs about 42 mph. When I ran 3800lbs of ballast the fuel just disappeared.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Tigé Jedi
- Jul 2010
- 4305
- TN USA
Originally posted by SPBFAN View PostThe fuel will be about the same and the more control in reverse Welllllllll, unfortunately you will have no control in reverse on this type of boat.
Actually, what I've found in very limited experience so far is that with the wheel turned all the way one direction, the boat backs up to the right. With the wheel turned all the way in the other direction, the boat backs up to the right a little less.
Just kidding... it appears I DO have some control over reverse direction, just not to the degree in my jetboat. The wonderful thing about a jetboat is that the impeller is spinning all the time, and that fore/aft is controlled by the thrust reverser and its ratio of forward to rearward thrust. This yields a VERY fine degree of control; you can feather F/R without shifting (because there IS no transmission at all). You can approach docks or other boats at any speed and have complete control over where you are and how fast you are going. It spoils you for other types of boats.
Ah, but times change and so does what we want to do with our boat. We are gaining professional class wakes and surfable waves, and losing maneuverability and serviceability.
Ah, but times change and so does what we want to do with our boat. We are gaining professional class wakes and surfable waves, and losing maneuverability and serviceability.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
