2002 23v
At the end of this year I'm going to be pulling my engine so I can change the gear ratio in my v-drive to the current 1:1.46 gear ratio. The problem I'm thinking about right now is that my strut was designed for a 13" prop, therefore if I want to upgrade to the 14.25 x 14 prop I will not have clearance.
Therefore I'm trying to find out what the right shaft strut to get so that I can run the bigger prop. I know that my boat had the option to have a gear reduced v-drive therefore I know a strut must have been available at the time to accommodate a larger prop?
) You may want to try PM'ing Dom, KKO, or SBFAN. Good luck with your project and keep us updated
